Ok so I have a older graphics card in this system and im using a dvi to hdmi adapter to connect it to my tv, so no sound. The card has spdif on it but I chose to go with onboard motherboard sound instead.
So I have a cable, forgot the name of it running from the audio out port from my motherboard to the audio in on my tv. Now my problem is the audio and video are working on different inputs?
So for example my graphics video is running on HDMI 3 input to tv and my audio is running on HDMI 4 input to tv. So when im on hdmi 3 channel only video shows when im on hdmi 4 channel there is only sound no video?
I hope ive made it clear so when there is sound there is no video when there is video there is no sound as they are on different input channels on the tv.
When i go into controll panel sound and hardware it shows 3 different output options and ive tried them all but no luck. Also the little green bar showing sound levels is working so i know there is sound out but just on a different channel.
How do I make it work together?
I had something similar running a while ago on my tv but I remember it was straight plug and play.
Id really appreciate any help.
