Hello all,
So I'm waiting to get 2 Samsung 830 128GB SSD this week.
I want to Raid 0 them both.
The question is what's the best way to do it.
My mother board is the Asrock z77 extreme9. It has:
2 SATA3 6GB/s intel - supports Raid.
4 SATA2 3GB/s intel - supports Raid.
4 SATA3 6GB/s Asmedia - doesn't support Raid.
Currently the windows is installed on a crucial c300 128GB SSD which is connected to one of the Intel SATA3 port.
These are the options:
1) Install the new 830 SSDs in the Asmedia ports (which are SATA3) and use software Raid.
2) Install the new 830 SSDs in the Intel SATA3 ports, install windows on them and use the hardware Raid.
3) Install the new 830 SSDs in the Intel SATA3 ports, but boot from the current crucial c300 (will be connected to the Asmedia SATA3 port) and still use the hardware Raid.
4) Buy a separate Raid controller and connect the 830 SSDs to the Raid controller. will boot from the crucial SSD connected to the Intel SATA3 port.
5) Other suggestions?
In case you think that I should get a Raid controller, could you suggest a hardware Raid controller that's compatible with a consumer/workstation machine?
In case of other suggestions, could you please elaborate?
Thanks!
Shai
Thanks!
Shai
