Caveman656
Here is my Rig
Do you think I can make this any more tidy?
you could also go ahead and sleeve the cables if you have the patience^^
Where did you get those orange fans? i really love them![]()
Or he could get pre-sleeved ones through NZXT.
Nice rig!
They might actually be red and in that case they are CoolerMaster Megaflows.
I don't think so because the front 230mm fan looks red and the other look orange
whats this bit all about??
Very nice, how much that cost all in all?
Love it.
Just a couple of tips: Firstly, lose the tacky bit you used to cover up the blue LEDs. If they bother you that much...paint them in with a black permanent marker or some black paint. As long as you're extra careful it could look good without causing damage to the board.
Next: Do what TTL suggested and run the 8pin power connector through the backplate access cut-out.
