H100 Push/Pull Configuration Question
Resonance
I just purchased a H100 and just used the stock fans to push air through the radiator to the top of the case... but i was wondering if it would be "decent" to use two 140mm nzxt stock fans to pull the air up? though, i'm currently using those two fans on the pivotal region on the switch 810, where the harddrive cages are, too push air up on the gpu. i doubt they are cooling the gpu at all since i'm not seeing any temperature difference with the gpu. Or should I just invest in some better fans, that would be the same, that i can use for push pull?
Yea use 120mm fans for push pull...
and if you want to use the ones (connectors) on the pump IIRC they need to be the same as the ones that come with the H100...
Id be looking at getting the new SP120 fans mate, dont connect them to the pump either just fix the fan speed and connect them to the psu via molex. if you want it quieter use the fan speed reducers.
