Hey Tom et al,
Just watched the 2nd Aquatuning Vid and thought would take a look at the Phobya gear as your using that humungous Phobya case.
Any chance of testing the H100 with the Phobya Nano-2G 12 Fans..... Would be great to have a pretty looking setup instead of the horrible brown Noctua's!!!!
On the "face of it" it would seem that the Phobya fans may "eek" out more cooling from the H100 at the same, or even reduced, noise levels..............
Phobya Nano-2G 12 PWM Silent 1500rpm
Red LED Double Blade (120x120x25mm) Vs Noctua NF-P12 Vortex-Control 120mm Fan
1) Rated speed: 1500rpm (+ / -10%) +15% 1) Rotational Speed: 1300 RPM (+/- 10%)
Airflow: max. 109.33 CFM +101% Airflow: 54.3CFM (92,3 m³/h)
Volume: 25 dBa +26% Volume: 19.8 dB(A)
2) Rated speed: 600rpm (+ / -10%) -54% 1) Rotational Speed: 1300 RPM (+/- 10%)
Airflow: max. 64.16 CFM +18% Airflow: 54.3CFM (92,3 m³/h)
Volume: 10 dBa -49% Volume: 19.8 dB(A)
2) Rated speed: 600rpm (+ / -10%) -45% 2) Rotational Speed L.N.A: 1100 RPM
Airflow: max. 64.16 CFM +39% Airflow with L.N.A: 46.2CFM (78,5 m³/h)
Volume: 10 dBa -41% Volume with L.N.A: 16.9 dB(A)
2) Rated speed: 600rpm (+ / -10%) -34% 3) Rotational Speed U.L.N.A: 900 RPM
Airflow: max. 64.16 CFM +72% Airflow with U.L.N.A: 37.3CFM (63,4 m³/h)
Volume: 10 dBa -21% Volume with U.L.N.A: 12.6 dB(A)
Volume: 10 dBa
Its not possible to "scale" the manufacturers info so had to work with what they provided.
Paul
Volume: 10 dBa
Paul
