Sooooooo you bought a Netburst processor ( dunno why since A64 is faster and cooler but ohh well , your choice
) and you want to overclock it. You buy the BEST retail HSF available in the market , install it , check your temps and go WTF MATE !!! 50C idle ???? And then the reality dawns ........ the bloody IHS is not flat. Good luck trying to overclock like that.
Buuuuuuut , thankfully since I was bored today and I had enough time to actually document my task , I decided to write up a nice and easy guide for you guys ...... So sit back , crack open a beer and enjoy !
Lapping an LGA 775 CPU
Items Needed : 1) Lapping Paper - 220,400,600,800,1000,1500,2000 and 2500 for that mirror shine which will make your girlfriend want a 125 Dollar pocket mirror :yumyum: .
2) Flat Glass Base
3) Paper Towels
4) A nice cool Ale
5) Alot of Elbow Greasing
Cost of the Project : Less than 15 USD
Timeframe : Approx. 1/2 Hour ~ 45 mins.
Right then , lets get on with it .......
1) Getting rid of the UGLY Nickel Plating :
Here is how the processor looks stock, unlapped .
The first step is to get a Permanent Marker and make markings on the IHS like in this picture. It will help you keep a track of how exactly uneven your IHS really was.
Ok now you are all set. Grab your sheet of 220 Grit Lapping Paper , place it on top of the flat glass surface. Do NOT involve liquid of any kind. You really dont want water/alcohol flowing under the IHS and shorting resistors. Now place the processor face down and start moving it in a circular path over the lapping paper. This is probably the longest phase on paper throughout the whole lapjob
. After a couple of mins you will seem something familiar to this .....
which in a few moments will look like this .....
Notice that the copper is starting to become visible now. This is a good sign , this means that you are breaking through the damn Nickel bond and getting to the good stuff. AWESOME JOB !!! Now take a swig of that brew of yours. Ready for more ???
Alright ....... keeping going in circles some more
Okkkkk , so some more Copper nakedness .......... boooooooooring. Can we go straight to the NC-17 stuff instead of this stupid PG-13 Crap ?? Neways carry on soldier .......
Ahhh Amateur Nudity !!!
. Now that you have gotten rid of the Nickel with splendor , its time to make the Copper all shiny. The circular pattern makes it easier to remove the nickel and gives you a nice and flat base to begin with.
2) Move up to the next grit , i.e. 400 . But now start lapping in a vertical fashion. This makes it alot easier and gives a better shine/flatness on bare copper. This has been my experience , dont quote me on though.
Every couple of minutes , switch the processor around 180 degrees and start lapping in the same fashion. This prevents the IHS from being thinner on one side and thicker on the other. Remember whenever you proceed to the next grit up , turn the processor 90 degrees or perpendicular to the direction of movement you used on the grit before. This will keep things even and smooth
The following pics are basically how your processor should look like through various grits of lapping .....
This was my final result. I only used upto 1500 Grit. I wasnt looking for a mirror effect. Just wanted a nice plain flat surface and I think that surface qualifies for those conditions very very well
Now I did not have a graph paper but I had something close to it. Let me know what you think about the reflection
You will definitely notice a remarkable difference in temperatures and will be thankful that you did it in the end.
Now your ale is finished and its time for you to give me your opinions about my first ever guide :wavey:
2) Flat Glass Base
3) Paper Towels
4) A nice cool Ale
