Guide: How batch process images (eg. Resize, Blur )
Batch process??
Performing one of the below procedures on a set of images.
What processes are supported by this method?
David’s Batch Processor (the GIMP plug-in that enables batch operations)
2 >> Install The GIMP
3 >> Install David batch Processor
·[font="] [/font]Unzip the required version to The Gimp’s Plug-in Directory
For Windows users this should be similar to
C:\Program Files\GIMP-*.*\lib\gimp\*.*\plug-ins [* is your version numbers]
How to use
Batch process??
- Blur
- Brightness/Contrast adjustment (auto adjust or manual)
- Image Resize
- Crop
- Sharpen
- Rename (best to perform this if you are running any batch process and the Source directory is the same as the output directory)
- Changing image format
- The GTK Toolkit (required for the GIMP to Work)
- The GIMP (GNU Image Manipulation Program)
- Linux
- Window
How to use
- [font="] [/font]Open The GIMP
- Open the batch editor plug-in
- Select Input files
- Processes you wish to perform on them
- Rename the output files (here I am adding the postfix ‘batched’)
- [font="] [/font]Go to the directory where the files are output to (default is source directory) and use as you wish.
