JezEngland
Hi,
recently I've corrected temperature and fan problems with the GTX 480. I get around 20-30 degrees cooler than standard using the same cooler and with lower fan speed. A link to the thread about that project is at the bottom of this post.
The EVGA card is factory overclocked at 726Mhz with 1.013Volts. The Point of View card is stock @ 700 Mhz and it's voltage is higher at 1.050 Volts.
I think experimenting overclocking should be done like with other components, doing a little raising extra voltage then frequency setting at a time.
OC'ing CPU has made my PC crash. What'll happen when the GPU is not stable? I need advice so to avoid problem like crashing etc.
I want advice on what voltage to use for a 750Mhz and 775Mhz and 800Mhz and other frequency's. Suggestions please
Thanks
Here is like a max overclock for the GTX 480: http: http://www.guru3d.com/article/overclocking-geforce-gtx-480-with-extra-gpu-voltage/
Here is a link to my cooler and quieter with reference cooler project thread: http://forum.overclock3d.net/index.php?/topic/32974-cooler-quieter-with-reference-cooler/
sorry wrong section
Thanks
sorry wrong section
