GTX 285 idle temps
KR_king
Hi I'm quite new to the forums so if there's something i should do, just tell me. c:
But my question is: I'm still running a GTX285 and it's quite loud.
So i turned the fan down to 30% and it's death silent. But then it idles around 60-62°C.
Is this still acceptable as an idle temp or is it better if i turn the fan up a notch? :confused:
Thanks! :)
Thanks! :)
Anything below 80 has no reason to cause you any trouble but make sure you crank the fan back up to whatever % keeps it below 80 when under load.
Load temps are around 80-85C 90 when i'm stress testing.
I adjusted the fan curve, not letting that hot head get over 85 in games.
