Dawelio
Active member
if the coil whine noise is the same as it was before the 290x then it wouldn't be the GPU. I know its probably hard to tell but some are worse than others
Yeah, now you've got me thinking :/... What if it's the motherboard?...
I've actually thought of upgrading to the MSI Z97M-G43 1155 motherboard and i7 4790K. Though those are expensive, specially the CPU.
