MicroAlex
Hey OC3D members
I do apologize in advance if my question is a bit incorrect or does not have a definite answer.
So I was wondering, how can I know if a GPU supports overvolting?
Is there some kind of a general rule for this? Is it only valid for high end cards?
There are a bunch of manufactures that make cards with nVidia and AMD chips on top.
Lets say we are looking at these:
AMD 7870
AMD 7870 LE
AMD 7950
nVidia 660
nVidia 660 TI
nVidia 670
Would it be down mainly to the manufacturer of the PCB and included components to allow/lock access to the manual voltage tweaking setting? If so, then how can we distinguish the ones which have that option from those that do not?
I do understand that you could go online and search the forums for a specific models and see if people had any luck changing the voltage on them, but I am hopping for an alternative option. With CPU's it is quite simple, pick lets say a K series processor and a motherboard with a compatible chipset for OC and you are good to go.
Way back I remember playing around with the Sapphire HD 4770 and it had that option for a small tweak if I started editing the BIOS, on the other hand the Gigabyte Windforce 6870 did not support such an option (at least at the time when I was messing with it).
I do hope my question is understandable in this case.
Thank you for your time.
AMD 7870
AMD 7870 LE
AMD 7950
nVidia 660
nVidia 660 TI
nVidia 670
