Alright guys,
I've got a bit of an issue after a recent GPU upgrade which is really annoying me now, as I had to purchase a new case to house this new GPU, my system as it stands:
Asus Formula V
AMD FX8350 CPU
16Gb G.Skill Ripjaw X's @ 1866Mhz
Corsair HX1050
Corsair Force 3 120Gb SSD
WD 750Gb SataII HDD
Sapphire R9 295X2
Windows 7 Ultimate (64 bit)
Drivers tried, 14.4, 14.9, 14.9.1, 14.9.2
3 x 24" LG IPS Monitors in Eyefinity 5760 x 1080
I basically upgraded my GPU to remove the twin card crossfire set up as I was having issues on BF4 with two cards, none of the drivers tried made a difference in Eyefinity it was unplayable.
So I removed one 7970HD and set it up with a mixture of Low, medium and high settings, the only "Ultra" setting was Mesh Quality. With just one 7970 on Eyefinity I was getting consistent 60 - 80FPS with only minor dips below 60 on certain maps. I played like this for ages, before deciding to upgrade.
On getting the R9 295X2 I was very, very impressed..... especially on 3DMark Firestrike and Unigine Valley the results were epic, on Extreme and Ultra presets. I tested the card with the benchmark tests on Just Cause 2 and Grid 2, all amazing.
However I purchased this card primarily for BF4, and whilst single player seemed very, very good on Ultra preset with Eyefinity, online Multiplayer would just not work, dropping as low as 25FPS. So I started doing some investigating and with the perfoverlay.drawgraph option enabled I could see that after a round or two the CPU was spiking really bad.
I decided to exit the game and start OC3D Hardware Monitor to check temps as I was playing the game. Reloading the game and playing a few rounds again saw the spikes return. On checking the Max Value of the GPU I was hitting 65 Degree's the CPU however was hitting 42 Degrees and the CPU load was 100% on all cores.
I'd just like to add, nothing is overclocked and even AMD's turbo core is switched off in the Bios... When this happens the game becomes unplayable and the BF4 graph is terrible where the CPU is concerned.
So I have this evening, removed the R9 and reinstalled my old 7970HD, game as before plays effortlessly smooth as butter in multiplayer, even on three screens. After about an hour I decided to check the temps again in Hardware monitor.
This time the GPU was showing 72 Degree's and the CPU 24 Degree's, the graph in BF4 was as expected almost perfectly horizontal and smooth, making the game a joy. I didn't catch what the total CPU load was with the single card, but I can always play again tomorrow and record that.
My question is, despite me using the latest GA and even beta drivers, why does my CPU Spike and run so hot when using the R9 295X2? Why is BF4 unplayable on this card / system in Eyefinity?!
I even had to buy a new case for the R9 card to fit in, and for the price of the upgrade I'm very disappointing in it's performance in BF4. Any help you guys can give would be greatly appreciated.
Asus Formula V
AMD FX8350 CPU
Corsair HX1050
WD 750Gb SataII HDD
Sapphire R9 295X2
