Tommy Steele 87
I've have a XFX R9 280X for a while now and it was running into the high 70s (°C) under load. So i decided to change the thermal paste. This seemed to help with the load temps bringing the load temps down to the 62-64 (°C). However i have noticed that the card idles around 46°C which is higher than the 39ish°C it idled at before. Does this seem ok? why would the load temps drop and the idle temps rise???
The case is a Fractal Design Node 804 With two intakes and two exhaust fans. I used isopropyl alcohol to wipe off the old termal paste and replaced it with IC diamond thermal paste (dot method)
Thanks for any input.....
