GPU Screws
dujames777
Does anyone know where I buy a set of GPU screw for a 780Ti shroud? I took it off for water cooling and has misplaced the screws, need a replacement set to put it back together.:confused:
Which 780Ti? Is it a reference card or 3rd party? If you can find at least one screw that fits, you could get it matched at a hardware store or somewhere like Maplins.
As Wraith says, Maplins is probably your best bet or any local electrical components store
