jamesriley94
Thought of finances and everything and decided that a full system loop is gunna be too expensive so i bought a D14 instead.
Now thinking that as I still have a bit of money left I may try and gpu only loop.
So, I have a few questions:
1) Would 1 of the alphacool ceramic pumps be enough for just 1 rad and the gpu block?
2) If so, whats the best way to mount one? I'd have preferred to go for a bay res/pump but if it's gpu only then I dont think that'll work.
3) What rad would you lot recommend? I'll be running 1 7950, may upgrade to 2 in the distant future so I'm thinking probably a 240 in the floor of my cm 690. Would an XSPC EX240 be alright for 2 in the future? I know it shouldnt have any problems managing one, and i'm pretty sure a 120 would do it, but for the price, I'm better off just going for a 240 I think.
4) Any other thoughts on this?
As I'd already planned to do a full loop I'm pretty confident everything will fit fine in the bottom, especially as I'd planned to have an RX240 in the bottom, I know thats pointless for 1 gpu.
Thanks for the help!
EDIT - oh, and what waterblock would you recommend? A full cover or just the gpu?
