hi all whats the best graphic card i can get at the momment for £100 give and take a few quid im not a fanboy of either just after the best i can get for my money thanks for reply
If you're looking at a 550 ti you maybe better of with one of these. http://www.aria.co.uk/Products/Comp...R5+PCI-Express+Graphics+Card+?productId=47975 Better parts so overclocking shouldn't be an issue.
I would of recommended my Asus GeForce GTX 550Ti 1024MB GDDR5 but they're no longer selling it at Aria and with regards to the three year warranty instead of ten, I myself would rather have a better cooler and parts on the GPU then a longer warranty.
That can take the strains of overclocking without damaging the GPU.
Mine runs flawlessly at a overclock of a 1066 core clock, shader clock of 2120 and either a memory clock of 2052 or 2155 at 1.2v but also bare in mind when altering the voltage profiles for the 550 ti bios using Nibitor do not, I repeat do not apply 1.2125v.
Set the 3d voltage profiles to either 1.2v and the limit at 1.2v or leave the first 3d voltage profile at its default value and then change the last 3d profile to 1.2v as well as setting the limit to 1.2v as you don't want to be throttling the GPU.
Also make sure you change the default minimum fan duty cycle for the GPU to 40%.
Edit
I've found my GPU here. http://www.overclockers.co.uk/showproduct.php?prodid=GX-270-AS&campaign=pcm/googleshopping
For a couple of quid over £100, scan are selling the superclocked FTW gtx 460, which is a great card And you can overclock the bejesus out of 460s for some hefty performance boosts
