GPU/CPU OC I7-3770K&HD7970ghz
D33M0
Hey OC3D Community,
first of i want to introduce myself,
im Andre from Crefeld, in Germany.
Im not a Nativ English Speaker nor writer but ill try hard.
I have been modding and experimanting with PC Hardware and Cases for Ages, so far my biggest OC achiement was an S775 Q6600 which i used for 3 Years and which is still running but with much to high Volts and Temps, which i just recently figured out through reading posts in this comunity and ofcourse TTL's Youtube Vids.
Well, im trying to find a way to configurate, modd and OC my new System...
PC Componnents:
Case: Nzxt Switch 810 GunMetall
CPU: Intels I7 3770K
GPU: XfX HD7970 BEDD 1050M
RAM: Corsair Vengeance 1600 Mhz 2*8gb kit
MB: ASRock Fatal1ty Z77 Professional
Primary HDD: Samsung SSD 830 256GB
Secondary HDD: Raid0 2* 500GB Seagate Barracuda
PSU: Corsair AX 860i
Pump: Laing DCC 12 T1+Phobya Pumphead
Radiators;
Top: Phobya G-Charger 360
Bot: Phobya G-Charger 240
Reservior: XSPC Frontbay 5.25 300ml
*Sarcasm on*
No TTL didnt talk me into buying most of my hardware, and he hasn't complettly changed the way i work with PC's.
*Sarcasm off*
Thank you, ttl, for this Community!
I am hoping that my PC will reach the following settings:
CPU: highest Posible Clocks before CPU reaches 75°c 24/7.
GPU: Core 1050@1200? Maybe; VRAM: 1450@1600? Maybe.
Ram: 1866 at decent steppings and settings.
I am also hoping someone here knows how to OC the GPU because i have never done that.
And obviasly i want you guys to see my System, tell me what you think and point out where i could improve myself. :D
I will also Post some Pictures here, hope that is fine with you.
:)Welcome to the OC3D forums D33MO,
That's a very nice system , there are alot of people here that can help with any question you might have . Enjoy:)
This thread could belong in 3 different sub-forums. Introductions, Rig Gallery, and Overclocking. It's fine where it is at the moment, but you may want to create a separate rig gallery thread, as per my PM.
Welcome to the forums! We can defintely help you with your overclocking - no problems at all.
Please start a new thread for each though because it would be very long to do all of this in one. I'd suggest a new thread in the CPU overclock section first, then one in the GPU overclocking section and I think that this should be moved to the build log because the pictures are sexy :D
thanks @M&P i will just do that ;D
@Josh if read it and thanks for the advise this is my first forum, if never done anything like this but i want to be a member of the knowlegbase that is build up here ;D Loving it.
@All Thanks for the Welcome.
Its Red yes ;D infect its so red, its starting to Leak Iron ;D
