Planning on watercooling my rig very soon, have a budget of about £500
I am planning on getting two rads as I cannot fit a quad rad in my case, So I am planning on a 360 triple rad and a single 140mm rad for the graphics cards.
I am worried about the flow of things within the case and if i should run 2 loops and pumps or a single loop with 2 pumps or whether 1 will suffice.
Not sure whether to cool the chipset or anything else other than the CPU and if its necessary
My equipment is
i7 980x
Rampage 3 extreme
2 x GTX480's
Haf x case
I have examined my case am Im certain I can fit those rads in their, so just a case of deciding on the rest of the stuff, probably will go for Swiftech Apogee GT block
and thermochill rads.
I am uncertain with regardsa tpo the water blocks for the graphics cards as I have heard bad things regarding GPU full cover blocks.
Pump is likely to be a Laing DD5 18w but do I need one or two please?
Cheers
My equipment is
i7 980x
Rampage 3 extreme
2 x GTX480's
Haf x case
Cheers
