Giggity
its as you disabled cool&quiet fella you will now see proper results,keep your CPU voltage at 1.45v AIR 1.5v Water
3.8 should be acheavble at 1.45v
also set your Ram to whatever speed it is,also set your NB multi to 10x that should take it just over 2000Mhz
Shes at 3.82 GHZ @ 1.472 Volts running around 29-30 idle no more than 47 full load.
@ diff fhz's OCCT yielded:
@3200 mhz (1.472v) = 45 degrees celcius
@3400 mhz (1.472v) = 45.5 c
@3600 mhz (1.472v) = 46 c
@3800 mhz (1.472v) = 46.5 c
All around 30 min tests, I know its not long but its sufficient to see what your max temp would be I think. Tonight Ill do a 8 hour test or something.
Im impressed with the H50 to be honest, some people complain that it doesn't idle low enough temp wise but what does that matter. At this point Im almost ready to give 4.0 ghz a shot.
EDIT: RAM now running @ 1600
You were able to get 3.6ghz at 1.09? So why do you need 1.47 for two mhz more??? That seems like total overkill to me.
he left cool&quiet enabled so it does not give valid results
LOL it would be awsome if he could get that clock speed at that voltage
Ya it was coolnquiet lol..1.09 volts @ 3.6 woulda been awesome :P So its 100 percent stable @ 3.82 @ 1.472 volts, and just OCd my 5850 to 850/1200 Mhz 1.11 v. I know I can go much more but I dont really need too at this point in time. Stock to oc 3d mark reflected 2300 point inc.
very nice mate,there aint no harm in tryin for 4Ghz for pure fun see if you can get into windows,if not just set it back ur current oc
