The Gelid Icy Vision Rev 2 GPU cooler comes with a 3 pin connector, but in the shape of a 4 pin connector (only 3 wires connecting though).
If I use it with the 30cm Akasa Fan 4 pin to 4 pin Extension Cable, and connect the PWM head to the GPU fan connector, will I be able to control the fan speed? Right now it only operates at 100% fan speed if connected directly to the GPU.
http://www.gelidsolutions.com/products/index.php?lid=1&cid=17&id=52
http://www.akasa.com.tw/update.php?...ype_sub=Fan Cable Adapters&model=AK-CBFA01-30
Many Thanks
Many Thanks
