GeForce Experience 2.0 Big Improvments
Dicehunter
Resident Newb
Loving this new software, Some great features :)
Release Highlights
GeForce Experience 2.0 Release Highlights
ShadowPlay
  • Adds support for GeForce GTX notebooks
    • GeForce GTX 800M, GTX 700M, and select GTX 600M GPUs supported
  • Adds support for desktop capture
    • Requires latest GeForce driver
    • Requires Aero mode enabled
    • Desktop GPUs only
  • Adds native 1920 × 1200 capture
  • Alt-tab will pause instead of terminate recordings
  • Video folders are now created when a video is saved instead of at game launch
  • Adds advanced quality options for Twitch streaming
  • Twitch streams will automatically be tagged with game name
  • Twitch streams now retain capture aspect ratio
  • Pause and resume broadcast
  • Fixes password handling bugs
  • Fixes bug where on-screen indicator cannot be disabled
  • Improves microphone audio quality
GameStream
  • Wake on LAN support: remotely wake up your PC from sleep mode
  • Remote Login support: login to a locked PC remotely from SHIELD
  • Manually add games to your GameStream list
    • Go to Preferences –> GameStream
  • Remote streaming support (beta): stream your PC games to SHIELD from outside your home
  • Notebook GameStream support (beta)
Bug Fixes
  • Various stability and bug fixes
Learn more here
Download
- http://www.geforce.com/geforce-experience/download
Didn't work on my laptop with a GT 650M... Geforce Experience never really works properly for me, so I just uninstalled it all now. I don't NEED it, right?
