You should invest in an alphacool DDC top for the pump, improves performance loads and you can insert LEDs into it as bling is clearly your thing. Also it supports 1/2" barbs so you will actually not be at risk from leaks (as you currently are).
Also: your loop design is a little poor you are creating a little kink where you move from rad to cpu block.
You would be better going from pump to the far rad barb (basically just switch which in and out you use on rad) or possibly swaping the cpu block around to give you some more room to move the tubing.
Edit: Ah sh1t, I think you might have loop order mucked up, is your cpu block the same on both sides? From this angle it look looks like it should have a specific in and out which you have wrong, even if theyre not you should swap them to try and remove that kink!
