Gaming PC for around £600 - HELP ME =)
iain.waller
Budget: £500-650 (£700 is absolute MAX, and only if significant improvement)
Main uses of intended build: Gaming, Sony Vegas (Premiere potentially) Browsing/Schoolwork
Parts required: All
Previous build information (list details of parts): Athlon x2, M4A78, 4GB, 500W Corsair
Monitor resolution: 1080
Storage requirements: Currently have a 1TB HDD, partitioned 750:250
Will you be overclocking: Depends if a significant increase would be worth the risk
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): USB3, but I reckon most have this now?
Extra information about desired system: Games such as BF3/Skyrim, and hopefully be able to run most upcoming games at reasonable settings.
i3 2120 £90
Z77 G43 £65
670 £300
Mushkin Blackline Frostbyte £40
500w Silverstone Strider £60
Then choose case and HDD. If you're selective with these, you could probably fit an SSD in too.
Thanks, would I gain much improvement from Oc'ing the i3, if so, what heatsink do you recommend?
i3s are ok for now. I don't think they will last long as applications become more demanding.
A cm hyper 212 will be an ideal cooler for the Ivy i5 or sandy i3. Great value.
