Futuremark Launches 3DMark 11, Trailers, OC Competition
why would they add that
imo it makes it look like it was made before 3Dmark03
it might look better on the extreme preset but cba to pay for it when it doesnt even support SLI
They would add it because it's testing something. Maybe CUDA? I don't know dude. I know I have seen video games do that before on the PC. Crysis for example when you get interference from the aliens.
P7587
http://3dmark.com/3dm11/37443
Says SLI is disabled, but SLI must surely be working to get that score. Once I had my CPU overclock under control, the bench ran fine (3rd time). Just like Vantage, if your overclock isn't stable, it crashes at the physics tests.
I'm using the 265 drivers.
I get P4491 3d marks, but says Your result has the following problem(s) and will not be shown for example on leaderboards: Graphics driver is not approved. This is with ATI driver version 10.10 downloaded from AMD website!!!!!!
fix it soon
shouldnt have even been broke in the first place
well considering the launch was the same time as a NV card
someone who works there most have sunddenly thought that SLI wasnt supported before they realeased it
there is no way this should have released without sli, its not like they wouldnt have had plenty of there cards out there in all its just an epic fail
4243 for me all at stock settings.
Same error graphics driver not approved.
Will start ocing soon again and see what i can squeeze outta this rig.
Nope, a SLI tweak
The problem appears on sli rig only but there is a solution!
It solve the combined test problem on sli setup too:
-download nvidia inspector
-click on the button near the driver name
-it open a new screen
-in the first group of keys modify the Sli compatibility bits(DX10) from 0X00000000 to 0X008000F5
-apply change
-run your bench as usual
for me it works great increase the combined test from 10fps to 40 and run Vantage great artefact free!
http://futuremark.yougamers.com/forum/showpost.php?p=1487517&postcount=13
Edit: No idea what that does, but it gives quite a boost.
