Fractal Define R6 Review
Might be a stupid question, but considering how heavy 3.5" HDDs still are, is 1 single thumbscrew really enough to keep it from sagging down or even breaking off? You might think, they've tested it, but it doesn't look very sturdy. Transportation might be a little scary as well.
I'd like to get it though, but I'm not a watercooler yet and this case seems like it would be a waste to not throw in a rad at the top :D
Doesn't look too bad since the brackets slot into the vertical panel as well. I'd worry more about your GPU in transport.
I can speak from experience (the S has a similar mounting system), it's fine to use with 3.5" mechanical drives.
As for the watercooling, yeah, that's one place i would put a rad....
