Fractal Define R3 Window!
infrinous19
Hey Overclock 3d forum peoples!
This is the build log of my window for my R3 case:)
hope you enjoy!
Before Lighting!
After Lighting!
Cutting the window!
Yea, I still kept the sound dampening material
Need my Scissors , Super Glue and Carpet tape
Keep it tidy
Done:)
Up Close and personal! (Removed stupid Zotac Sticker
- Yea I know there is still touchups that can be done, we're working on it,
Hope you like it
Looks great! I've been considering getting the Fractal XL to replace my Phantom, and a window mod like yours on the XL could look amazing.
Wow, that's a really nice build you have. That's a tight fit with the H80 and the top exhaust fan.
Lmfao it was a tight fit
and for the cut I used a Plasma cutter
specs are :
i7-920 4ghz
Sabertooth x58
6gb mushkin blackline 7-9-7 1600 mhz
2x500gb raid 0
1x64 gb Kingston vnow 100
gtx 580
hale82 850w
shitty dvd drive that I never use
nzxt blue sleeved led kit
H80 cooler
Fractal R3 - obviously
Thats about it
Great taste in components.
How is the Hale82 performing? That's the bronze rated series I recall. The Hale90s were very good and very silent. Hope NZXT continues to produce high quality PSUs with the same or with better consistency like those from their Hale90 line.
This is a silly question, but is this your most recent build?
Hmm, the hale82 I have had some...doubts about, should I bring it back should I keep it. I think I am going to keep it because I'm too lazy to unplug it all haha
Its easily the loudest fan in the case and you hear it when its under load, shame but oh well.
This is my most recent if you dont count the average computers I built for my family and such.
By far the most expensive
I would have thought the Corsair H80 fans would be the loudest amount the fans in your system.
Maybe the next time around you could take a look at the be quiet! or Seasonic PSUs. They are by far the quietest among many PSUs I've used. No doubt, the gold rated AX PSUs from Corsair are also excellent.
If you're going to be keeping this system for the long run, I'd definitely recommend getting a reliable and quiet PSU.
It's definitely a great system. I was meaning to ask earlier why you didn't opt for a 1155 based system instead.
A little bit louder but a lot worth it haha. And when I started the build 1156 had JUST came out and I didn't want it haha. I've been through many upgrades. Only the CPU is the same
