Had my 2500k for 5yrs 1 month and think it's probably due an upgrade. I don't think I'll get massive performance increase but I'm interested in new motherboard features. Do you think it'll be worthwhile?
Current build
2500k @ 4.7ghz
CM 212+
MSI Z68 GD55
GIGABYTE GTX 970 G1
Rippler 8gb @ 1600mhz
Corsair 650w Tx2
Samsung 840 Pro 256gb
Samsung 840 Evo 250gb
Samsung 850 Evo 500gb
Lian Li PC-70
New Parts (will be using everything else from old PC)
i7 7700k
Noctua NH-D15
ASUS Z270-A Prime
Kingston Savage 32gb 16x2 @ 2666mhz
Fractal Define C
I should be able to get all this for about £400 which is considered cheap perhaps but still a chunk sum.
Current build
2500k @ 4.7ghz
CM 212+
MSI Z68 GD55
GIGABYTE GTX 970 G1
Corsair 650w Tx2
Lian Li PC-70
i7 7700k
Noctua NH-D15
ASUS Z270-A Prime
Fractal Define C
