sheroo
OK guys, I have yet more questions... This time specifically about folding on NVidia GPU's.
1. It seems as a rule of thumb (whether under Linux or Windows) that 1 CPU core should be "allocated/available" for each GPU you're folding on. Does this include hyperthreading? i.e. What is the theoretical number of GPU's that a 2600K will support? Could you in theory run 8 NVidia GPU's or are you limited to 4 GPU's matching the 4 physical cores?
2. Does using a Pci-e 1x 16x riser powered cable affect the GPU performance in terms of PPD when folding? (these seem to be used quite a lot in mining rigs so you can space out your GPU's and have up to 6 GPU's hanging off a single motherboard).
EDIT: OK after doing a shed load of research this morning it appears that hyperthreading is counted in the core count. So in theory a 2600K could support 8 GPU's if that were physically possible.
