Brian18741
Hey Guys, I'm new!
I'm going to put this here;
----tl;dr----Best fans for quiet watercooling set up and how to controll them without 5.25" fan controller?!
Anyhoo. Planning my first loop at the moment. Have it pretty much speced out but need help with the fans.
Vital statistics:
Now, how to control the fans? Before we get too into it, I will have no 5.25" bays so no option for 3rd party fan controllers.
Can I connect all fans to something like a Swiftech 8 way PWM fan controller PCB and have all fans PWM controlled by the CPU? The Swiftech PCB takes power from a molex connector so that should take the load off of the CPU fan header and eliminate the risk of the header burning a hole in the motherboard, correct?
But is it ok to have the fans PWM controlled my the CPU temps when there will be two GPUs in the loop as well? Will the GPUs suffer as a result as their load may be a lot higher than the CPUs.
Or is the fact the GPUs will be connected to a 45mm thick 360 rad and a 30mm thick 240 rad mean they are going to be substantially cooler regardless as long as the CPU is being cooled?
-----OR-----
I have an NZXT Phantom 410 with inbuilt fan controller. If I use something like a Molex powered Mod My Toys fan splitter PCB, can I regulate the voltage with the inbuilt fan controller in the case? This PCB is also power by molex so how could I use that in conjunction with the inbuilt fan controller? Realistically I would only need two steps, low and high.
-----FINALLY-----
About the fans. I've heard of problems with PWM SP120s when several are used, see quote:
If not SP120s, what fan to use? I was also looking at eloquently named Noiseblocker Eloop B12-PS or the Alpenföhn Wing Boost Plus PWM.
Noctua NF-F12 PWM 120mm Focused Flow PWM and the Sythe Gentle Typhoon AP15 (PWN version?) are regularly recommended but that will require painting them as I'm going for a black and white theme. So I'll do it if I have but would like to cut down the work load a bit as I'll be making all custom cables, an acrylic PSU cover, not to mention the acrylic loop and modding the bejeebus out of the Phantom 410 to get everything to fit in!
Thanks for your help in advance!
Vital statistics:
- 3570k and R9 290 crossfire.
- XSPC Raystorm and two EK FC gpu waterblocks.
- EK-D5 Vario X-RES 140 pump/res combo.
- Tubing will be acrylic, unsure about diameter and fittings, something like 1012mm ID/OD and Bitspower Black Sparkle.
- Aplhacool XT45 360mm rad push/pull and ST30 240mm rad push config.
- 8 SP120 quiet edition*
-----OR-----
-----FINALLY-----
The reason not to use the Corsairs, is that they do not conform to the Intel PWM standard, and once you have more than a few of them on a mobo CPU header, they loose lower speed control, and with enough of them, they just ran at max no matter what the pulse width percentage is.
