Hello there, I just recently got my D14 and did my first overclocking to 4GHz.. IMO temps seem a bit high for a D14, it has good airflow in a RV02 case..
Prime95 ran for 12 hours, no errors.
Prime for 30min, temps:
Idle temps are: 40 - 34 - 40 - 34
Ambient temp: 22-24C (Max/Min) through all testing/OC'ing
Amount of thermal paste, used the Noctua stuff that came with it.. Too much?
BIOS Settings (Gigabyte UD3R X58)
Multiplier: 23x
Base Clock: 174
CPU vCore: 1.28750
QPI Link Speed: 6.266GHz
Uncore: 3480MHz
System Memory Multiplier: 8.0
Memory Frequency: 1392MHz
DRAM Volt: 1.5v
Load Line Calibration: Standard
QPI/Vtt Volt: 1.175
CPU PLL: 1.800
I read that I coult pretty much leave anything other than BCLK, Multi, vCore and RAM Multi at auto.. So everything other than those settings are on Auto in bios.
Im wondering if it is my CPU or mobo limiting me or the RAM, cause I have problems at some settings, it just restarts right after clicking F10 and accepting.
It does this if I try pretty much any multi and base clock for 4.2GHz.
I try to take the volt one click up or down from on the setting im at now (4.0GHz).
It wont boot with any setting I have tried at CPU volt of 1.3 or higher.
The volt im at now in the bios is the only one working properly for 4GHz+ clocks, and its not close to the volt needed for 4.2GHz.
Im happy with the overclock, pretty low volts imo for 4GHz, but my temps seem a bit high for a D14 I think
Cheers
Multiplier: 23x
Base Clock: 174
CPU vCore: 1.28750
Uncore: 3480MHz
DRAM Volt: 1.5v
QPI/Vtt Volt: 1.175
CPU PLL: 1.800
Cheers
