| raVen |
Member
Heyllo
I'm planing to watercool my system for the first time ever
So I may need some advice from all of you.
I have Rv03 case so I can mount 240rad in front of the case.
I was looking for parts from specialtech(TTL recommending this shop in his videos on YT).
And I choose some parts
- Phobya G-Changer 240mm Dual Radiator
- XSPC Rasa CPU Waterblock
- Phobya DC12-260 600LPH 12V Compact Pump
- Phobya Balancer 250 Reservoir Black Nickel
- Masterkleer 1/2" ID - 3/4" OD (13-19mm) 'Retail Box' 3.3m (10ft) Tubing : Clear
- Pulse Modding 99.9% Silver Kill Coil
- EK PSC 1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing : Black .x4
- Bitspower 1/4" Thread 45 Degree Rotary Compression Fitting for 1/2" ID - 3/4" OD Tubing Matt Black .x4
- Mayhems X1 Premix Fluid for Water Cooling 1 Litre : Clear / UV Blue .x3
- Mayhems Dye 5ml Dropper Bottle : Green / UV Green .x2
Do I need anything else??Looks good or I did something wrong?
Thanks for any help
Thanks for any help
