mrDMxtreme
So i finally got around to my rig, and i just upgraded the bios of my M.IV.E and i started,
so far i'm at 4515MHz with a high of 66C with prime running (sry can't get the delta cuz i don't have the room temps, but its pretty warm cuz its a small room i'm in right now)
i'm going to set the voltage to 1.35 and then see what the max stable OC is, then if i'm not happy i'll be trying to go higher
i also have a question, does anyone know if asus can get a OC without only using turbo? because i know a few companies are allowing that, but not all.
and another question, what is igpu? and can i/should i turn it off?
Thanks guys, i'll keep you posted
