Firefox 1.0.5 released
Joe
Download Links :A new version of Firefox with the following improvements:
·[font=&quot] [/font]Several security fixes.
·[font=&quot] [/font]Fixed in Firefox 1.0.5
MFSA 2005-56 Code execution through shared function objects
MFSA 2005-55 XHTML node spoofing
MFSA 2005-54 Javascript prompt origin spoofing
MFSA 2005-53 Standalone applications can run arbitrary code through the browser
MFSA 2005-52 Same origin violation: frame calling top.focus()
MFSA 2005-51 The return of frame-injection spoofing
MFSA 2005-50 Possibly exploitable crash in InstallVersion.compareTo()
MFSA 2005-49 Script injection from Firefox sidebar panel using data:
MFSA 2005-48 Same-origin violation with InstallTrigger callback
MFSA 2005-47 Code execution via "Set as Wallpaper"
MFSA 2005-46 XBL scripts ran even when Javascript disabled
MFSA 2005-45 Content-generated event vulnerabilities
·[font=&quot] [/font]Fixed in Firefox 1.0.4
MFSA 2005-44 Privilege escalation via non-DOM property overrides
MFSA 2005-43 "Wrapped" javascript: urls bypass security checks
MFSA 2005-42 Code execution via javascript: IconURL
·[font=&quot] [/font]Fixed in Firefox 1.0.3
MFSA 2005-33 Javascript "lambda" replace exposes memory contents
MFSA 2005-34 javascript: PLUGINSPAGE code execution
MFSA 2005-35 Showing blocked javascript: popup uses wrong privilege context
MFSA 2005-36 Cross-site scripting through global scope pollution
MFSA 2005-37 Code execution through javascript: favicons
MFSA 2005-38 Search plugin cross-site scripting
MFSA 2005-39 Arbitrary code execution from Firefox sidebar panel II
MFSA 2005-40 Missing Install object instance checks
MFSA 2005-41 Privilege escalation via DOM property overrides
·[font=&quot] [/font]Fixed in Firefox 1.0.2
MFSA 2005-32 Drag and drop loading of privileged XUL
MFSA 2005-31 Arbitrary code execution from Firefox sidebar panel
MFSA 2005-30 GIF heap overflow parsing Netscape extension 2
·[font=&quot] [/font]Fixed in Firefox 1.0.1
MFSA 2005-29 Internationalized Domain Name (IDN) homograph spoofing
MFSA 2005-28 Unsafe /tmp/plugtmp directory exploitable to erase user's files
MFSA 2005-27 Plugins can be used to load privileged content
MFSA 2005-26 Cross-site scripting by dropping javascript: link on tab
MFSA 2005-25 Image drag and drop executable spoofing
MFSA 2005-24 HTTP auth prompt tab spoofing
MFSA 2005-23 Download dialog source spoofing
MFSA 2005-22 Download dialog spoofing using Content-Disposition header
MFSA 2005-21 Overwrite arbitrary files downloading .lnk twice
MFSA 2005-20 XSLT can include stylesheets from arbitrary hosts
MFSA 2005-19 Autocomplete data leak
MFSA 2005-18 Memory overwrite in string library
MFSA 2005-17 Install source spoofing with user: pass@host
MFSA 2005-16 Spoofing download and security dialogs with overlapping windows
MFSA 2005-15 Heap overflow possible in UTF8 to Unicode conversion
MFSA 2005-14 SSL "secure site" indicator spoofing
MFSA 2005-13 Window Injection Spoofing
MFSA 2005-12 javascript: Livefeed bookmarks can steal private data
MFSA 2005-09 Browser responds to proxy auth request from non-proxy ssl server
MFSA 2005-08 Synthetic middle-click event can steal clipboard contents
MFSA 2005-07 Script-generated event can download content without prompting
MFSA 2005-05 Input stealing from other tabs
MFSA 2005-04 Secure site lock can be spoofed using view-source:
MFSA 2005-03 Secure site lock can be spoofed by a binary download
MFSA 2005-02 Opened attachments are temporarily saved world-readable
MFSA 2005-01 Link opened in new tab can load local file
·[font=&quot] [/font]Improvements to stability.
very good work there.
I am updating my FF through the implemented Updates system which gives me a message if a new update is realeased.
Yeah I checked for updates with the FF options but it did not come up :(
name='NickS_' said:
Hey I use IE too.
wow you guys are making it harder for us webdesigners. The IE is killing me. All the time i have to change code segments just because this wonderfull piece of *work* compiles it wrong.
I.E is soooo much simpler, and it dont have ne crappy tabs to keep track of, and if i want a google tool bar i wil download one, I.E just had a more professional feel about it
wow you are experiencing very weird things there. I dont want to start a FF vs IE User fight but IO i have to tell you that your arguments are not realy worth that much because to each of these you could get anotherone easily back.
Who knows maybe the MS ppl learned and will do a better job in IE 7 (BTW IE 7 will support tabbed browsing IO ;) )
See I like tabbed browsing, but IE is much more cleaner and faster in my mind as it's integrated right into Windows Explorer. (Faster App Wise, Internet Wise It's The Same)
The IE starts faster then the FF only if you did not optimize (preload the FF) the FF. with the Firefox you have to optimize some stuff youself so it runs even faster as it allready does.
Nah anyway like i said. Lets see what IE 7 brings.
nick you where winging how shit IE was a few months ago
No I've never winged about how shitty IE is because I switch back and forth a lot. I go FireFox for a bit, then I go to IE. idk i just do that.
