Rastalovich
For those interested:
Ftp Linky
Fixed Bugs: (Mac/Lin/Win/All)
#251910 [Firefox
laces]- No hover highlighting (i.e. mouse-tracking) in Bookmarks/History sidebar [All]
#339754 [Core:Installer: XPInstall Engine]- Threadsafety asserts from chrome registry when installing extensions [Lin]
#368811 [Firefox:General]- Firefox crashes on exit after plugin install activated by InstallTrigger. install(xpi, installCompleteFunction) [Win]
#386065 [Core:Layout: Form Controls]-legend {font-size:0;} still shows the text (yahoo.com mainpage) [Win]
#386551 [Core: Disability Access APIs]- expose ARIA description on document [All]
#386585 [Core:ImageLib]- Update libpng to version 1.2.21 [All]
#391740 [Toolkit:XUL Widgets]- listheader in richlistbox appears to right/at bottom of richlistitems [All]
#391868 [Core:Layout]- Page Source very small with meta charset=windows-1258 [All]
#394805 [Core:Layout: BiDi Hebrew & Arabic]- “ASSERTION: ResolveBidi called on non-first continuation” [All]
#396745 [Directory:LDAP XPCOM SDK]- nsILDAPConnection: :Init should take an nsILDAPURL as a parameter instead of three others. [All]
#397135 [Toolkit:XUL Widgets]- tree._ensureColumnOrder dies if no columns are defined [All]
#397288 [Core:GFX: Thebes]- Missing text without fallback from U+0000-00FF fast path when first font-family doesn’t have necessary glyphs [Lin]
#397296 [Firefox:Build Config]- Firefox builds need to use the current NSS CVS tag [All]
#397434 [Firefox
hishing Protection]- Phishing update request is malformed [All]
#397518 [Core:MathML]-” ASSERTION: The block in an {ib} split shouldn’t be living inside an inline” with mathml [Mac]
#397796 [Toolkit:XULRunner]- Allow XULRunner apps to specify the name of xulrunner-stub via configure [All]
#398056 [Toolkit:Breakpad Integration]- symbolstore.py does not recognize srcdirs with SVN when using svn-ssh [Lin]
#398363 [Core:Widget]- Removing Cairo Checks in nsBaseDragService [All]
#398512 [Core:Widget: Gtk]- crash on shutdown and before restart (gdk_display_close) with gtk xim module [Lin]
#399048 [Core:Security: UI]- Add accesskeys to all buttons, make Get Certificate the default button (Add Exception dialog) [All]
#399050 [Firefox: Download Manager]- directories created with wrong permissions [Lin]
#399136 [Directory:LDAP XPCOM SDK]- 396745 broke nsLDAPChannel.cpp [Lin]
#399259 [Firefox:Form Manager]- Form manager shouldn’t cache Login Manager service at startup. [All]
#399354 [Core:SVG]- Some SVG filters not checking in2 requirement [Lin]
#399440 [Firefox:Menus]- Work offline menu has incorrect state after cancelled request to go offline in sub windows [Mac]
Ftp Linky
#251910 [Firefox
#397434 [Firefox
