*** See last post
I can still remember 10 years ago lurking the FM forums and seeing all of the sweet looking watercooled PCs. Well, I've finally grown a set and feel it's time I take the plunge into watercooling (not counting the H50). I'm doing the research now, but won't be buying until closer to Christmas.
For now I'm just going to cool my i7 930, the 470 blocks are just too expensive for my budget right now. I'd like to run at 4.2GHz 24/7. The CPU can do that no problem, but the H50 can't keep up. I can fit two 140x2 rads in my case so I could expand later if I decide to cool the GPU/GPUs as well. I have the CM 690 II Advanced Case and can put the radiator in the top or bottom.
This is what I am looking at so far for parts:
CPU Block:
Swiftech Apogee XT Extreme
Rad:
Black Ice GT Stealth 280
Pump:
Res:
Tubing:
Fans for RAD:
??? I want the best fans for the type of radiator I get.
Also, what kind of barbs should I get? What type is best to use and what size should I go with?
Now the fluid. Just normal distilled water? What additive is good to use? I'm fine with the once a year cleaning, but in between I want 0 maintenance. This rig will run 24/7 folding so everything needs to be reliable and stable.
Edit: Posting this at FM as well. Thanks for the help guys!
CPU Block:
Rad:
Pump:
Res:
Tubing:
Fans for RAD:
