Final Fantasy XIV: Heavensward Benchmark Utility
WYP
News Guru
A benchmark Utility for Final Fantasy XIV: Heavensward has been released, which includes all new detail and features to the game and support for DIrectX 11 and Multi GPU Setups.
Read more on the new benchmark for Final Fantasy online here.
Not a bad benchmark. Couldn't stay above 60fps the entire with everything at max settings. Ended up with a score of 10391.
i5-4670k @ 4.2Ghz (I should really work on this OC)
GTX 780 @ 1215Mhz
Very animated benchmark not really my thing.... I'm old as is my box X58 vintage but handled it well
David
Anyone have issues with this, i cant complete the benchmark, it crashes on the section with those owl looking things
Stage 4 i think
The more I play around with the 780 Ti and 980 the more I think the 980 is a waste of time.
1440P, Max settings minus AA.
980 with 1500 on the core and 7800 on the memory -
780 Ti with only the power and temp bar raised which resulted in a tiny overclock of 1100 on the core and nothing on the memory -
I'll do it again with a proper overclock on the 780 Ti but the 980 won't go any higher.
Why I would rather a GTX 980 over others cost/performance :D:D Av FPS 67 Max everything
David
David
Which preset is that ?
Can't see preset 1 in the options.
Or better yet which settings did you use ?
I used max settings minus AA on my 980 with a 1500 overclock and only got 7.9k.
Save highest quality settings DirectX 11 only and then change display to 1440 and run benchmark, you can set up more presets to suit your needs. check settings. :huh:
David
You see this is why I gave up the game of bench marking years ago, it always turns into a pissing contest, here is the save file sort it out yourself contest finished, I am happy and that is all that matters :D Oh! you did get that I was running OLD generation Mobo and CPU? and still I'm up there :o:D=00=
FINAL FANTASY XIV: Heavensward Benchmark
Tested on: 29/04/2015 21:40:42
Score: 8601
Average Frame Rate: 66.169
Performance: Extremely High
-Easily capable of running the game on the highest settings.
Loading Times by Scene
Scene #1 3.269 sec
Scene #2 14.493 sec
Scene #3 6.685 sec
Scene #4 6.446 sec
Scene #5 5.751 sec
Scene #6 3.055 sec
Total Loading Time 39.701 sec
DAT:s20150429214042.dat
Screen Size: 2560x1440
Screen Mode: Full Screen
DirectX Version: 11
Graphics Presets: Preset 1
General
-Wet Surface Effects: Enabled
-Occlusion Culling: Disabled
-LOD on Distant Objects: Disabled
-Real-time Reflections: Highest Quality (DirectX 11 Only)
-Edge Smoothing (Anti-aliasing): FXAA
-Transparent Lighting Quality: High
-Grass Quality: High
-Background Tessellation: High Quality
-Water Tessellation: High Quality
Shadows
-Self: Display
-Other NPCs: Display
Shadow Quality
-LOD on Shadows: Disabled
-Shadow Resolution: High - 2048p
-Shadow Cascading: Best
-Shadow Softening: Strong
Texture Detail
-Texture Filtering: Anisotropic
-Anisotropic Filtering: x16
Movement Physics
-Self: Full
-Other NPCs: Full
Effects
-Limb Darkening: Enabled
-Radial Blur: Enabled
-Screen Space Ambient Occlusion: HBAO+: High Quality (DirectX 11 Only)
-Glare: Normal
Cinematic Cutscenes
-Depth of Field: Enabled
System
Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150316-1654)
Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
12279.109MB
NVIDIA GeForce GTX 980 (VRAM 3072 MB) 9.18.0013.5012
Benchmark results do not provide any guarantee FINAL FANTASY XIV: A Realm Reborn (Windows version) and FINAL FANTASY XIV: Heavensward (Windows version) will run on your system.
FINAL FANTASY XIV: Heavensward Official Website http://eu.finalfantasyxiv.com/pr/
(C) 2010-2015 SQUARE ENIX CO., LTD. All Rights Reserved.
Share Results
Type 1
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8601 2560x1440 Preset 1 DX11 Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz NVIDIA GeForce GTX 980
Type 2
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8601 2560x1440 Preset 1 DirectX11 Full Screen NVIDIA GeForce GTX 980
Type 3
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Preset 1 DirectX11 Score: 8601 Extremely High
Type 4
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Preset 1 DirectX11 Full Screen Score: 8601
Full Results
No wonder you got higher you have a few FX disabled i.e -
Oh and FYI it's not a pissing contest, You Aussies always aggressively jump then gun, I was just wondering how you got such a high score when we pretty much have the same hardware :)
Its more about your comment 780ti vs 980 so in fairness I turned on what you thought I might have turned off! but is actually the default for the BM.
Anyway sorry! 980 handles it just as well
Tested on: 29/04/2015 23:34:05
Score: 8750
Average Frame Rate: 67.171
Scene #1 3.081 sec
Scene #2 12.968 sec
Scene #3 6.176 sec
Scene #4 6.177 sec
Scene #5 5.303 sec
Scene #6 3.053 sec
Total Loading Time 36.760 sec
DAT:s20150429233405.dat
DirectX Version: 11
Graphics Presets: Custom
General
-Occlusion Culling: Enabled
-LOD on Distant Objects: Enabled
Shadows
-Self: Display
Shadow Quality
-LOD on Shadows: Enabled
Texture Detail
Movement Physics
-Self: Full
-Other NPCs: Full
Effects
-Glare: Normal
Cinematic Cutscenes
System
12279.109MB
Share Results
Type 1
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8750 2560x1440 Custom DX11 Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz NVIDIA GeForce GTX 980
Type 2
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8750 2560x1440 Custom DirectX11 Full Screen NVIDIA GeForce GTX 980
Type 3
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Custom DirectX11 Score: 8750 Extremely High
Type 4
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Custom DirectX11 Full Screen Score: 8750
Full Results
David
Well I own both cards so it doesn't matter to me which is better ^_^
2160p max settings
4 TitanX @1455/2002
5960X @4.5
350.12 Drivers
Tested on: 29/04/2015 17:01:16
Score: 19366
Average Frame Rate: 148.224
Scene #1 1.093 sec
Scene #2 4.346 sec
Scene #3 5.081 sec
Scene #4 4.190 sec
Scene #5 4.256 sec
Scene #6 1.928 sec
Total Loading Time 20.896 sec
DAT:s20150429170116.dat
Screen Size: 3840x2160
DirectX Version: 11
Graphics Presets: Maximum
General
Shadows
-Self: Display
Shadow Quality
Texture Detail
Movement Physics
-Self: Full
-Other NPCs: Full
Effects
-Glare: Normal
Cinematic Cutscenes
System
Windows 8.1 64-bit (6.2, Build 9200) (9600.winblue_r9.150322-1500)
Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
16265.656MB
NVIDIA GeForce GTX TITAN X (VRAM 3072 MB) 9.18.0013.5012
Share Results
Type 1
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 19366 3840x2160 Maximum DX11 Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz NVIDIA GeForce GTX TITAN X
Type 2
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 19366 3840x2160 Maximum DirectX11 Full Screen NVIDIA GeForce GTX TITAN X
Type 3
http://sqex.to/ffxiv_bench_eu #FFXIV 3840x2160 Maximum DirectX11 Score: 19366 Extremely High
Type 4
http://sqex.to/ffxiv_bench_eu #FFXIV 3840x2160 Maximum DirectX11 Full Screen Score: 19366
Full Results
I did two runs with Maximum preset and it seem that the Nvidia streaming thing changes things a little
First run with streaming service runnning
Tested on: 28/04/2015 23:29:57
Score: 8338
Average Frame Rate: 63.941
Scene #1 0.859 sec
Scene #2 4.125 sec
Scene #3 3.612 sec
Scene #4 3.246 sec
Scene #5 3.063 sec
Scene #6 1.360 sec
Total Loading Time 16.267 sec
DirectX Version: 11
General
Shadows
-Self: Display
Shadow Quality
Texture Detail
Movement Physics
-Self: Full
-Other NPCs: Full
Effects
-Glare: Normal
Cinematic Cutscenes
System
Windows 8.1 Professionnel 64 bits (6.2, version 9200) (9600.winblue_r9.150322-1500)
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
8133.664MB
Share Results
Type 1
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8338 2560x1440 Maximum DX11 Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz NVIDIA GeForce GTX 980
Type 2
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 8338 2560x1440 Maximum DirectX11 Full Screen NVIDIA GeForce GTX 980
Type 3
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Maximum DirectX11 Score: 8338 Extremely High
Type 4
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Maximum DirectX11 Full Screen Score: 8338
Full Results
Second run with streaming service off and after reboot
Tested on: 30/04/2015 14:42:46
Score: 9298
Average Frame Rate: 71.210
Scene #1 0.911 sec
Scene #2 4.079 sec
Scene #3 3.466 sec
Scene #4 3.184 sec
Scene #5 3.092 sec
Scene #6 1.403 sec
Total Loading Time 16.135 sec
DAT:s20150430144246.dat
DirectX Version: 11
General
Shadows
-Self: Display
Shadow Quality
Texture Detail
Movement Physics
-Self: Full
-Other NPCs: Full
Effects
-Glare: Normal
Cinematic Cutscenes
System
8133.664MB
Share Results
Type 1
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 9298 2560x1440 Maximum DX11 Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz NVIDIA GeForce GTX 980
Type 2
http://sqex.to/ffxiv_bench_eu #FFXIV Score: 9298 2560x1440 Maximum DirectX11 Full Screen NVIDIA GeForce GTX 980
Type 3
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Maximum DirectX11 Score: 9298 Extremely High
Type 4
http://sqex.to/ffxiv_bench_eu #FFXIV 2560x1440 Maximum DirectX11 Full Screen Score: 9298
Full Results
There's no doubt for me that if you don't need to stream on a shield or to capture your gameplay, you'd be better to disable this service :)
