Final Checks! :)
Mhyles
Anything you would change?
i5 3570k
Hyper 212 Evo
Gigabyte Z77X-UD3H
Corsair Vengeace 8GB Low Profile
1TB Caviar Blue
128GB Plextor M5S
Sapphire 7950 Boost
BitFenix Shinobi
Seasonic M12II 620W
Thanks in advance. :)
I'd change the motherboard to an MSI Z77a-G45 as Gigabyte Z77 boards aren't the best.
And I'd also change the SSD to a Crucial M4 or Samsung 830.
I'd also think about a better case. Nothing wrong with the Shinobi, but for an extra £10-20 I think you could do quite a lot better with something like a CM690, or one of the Fractal cases.
James has got it spot on so all I can do really is echo what he has already said :) For Z77 MSI over Gigabyte, I notice that Gigabyte board is about the price of a GD55 so I would recommend that.
I have a 690 B&W edition myself and I think it is a pretty great case for the price tbh :)
Really, since when have Gigabyte boards been bad? I was gonna' go with the GD55, but decided against it due to aesthetics.
Don't like the look of the 690, and it's another €20 - 30 more, and I'm on a tight budget anyway.
What they mean is that the Gigabyte Z77 boards are not bad, but not as good as MSI Z77 boards. If you are on a tight budget then go with the Gigabyte UD3H, it's a decent board.
Plextor ssds are very good, especially the one you originally planned on getting. Msi have gotten the best mobos for z77.. Just dont expect to get your rebate back:(
