Fans for h100i at high heat loads
Vedge
I got myself an H100i kit recently and has been running it with a stable 4.2Ghz overclock on a first gen Core i7 930, with default fans
Now i'm thinking to upgrade my fans since the stock ones make quite a bit of noise at high rpm. The question is, however, which fans can i get that will perform as good, since I need to run the stock fans at 2200 at least to keep the temperatures under control at 100% load in prime95.
I was thinking of Noctua fans, since they have decent specs at highest rpm, while probably being more silent than the sp's from h100i kit.
Oh i see.. It's at 1.36V and at 100% load will hover around 80C. My custom profile runs from 1200 (inaudible) up to 2200 for high loads. In day to day use, when i'm not running any simulations it will hover between 50 to 65(gaming).
