dipzy
Active member
Hi guys, I've used this case for my build but i'm only using the 3 fans supplied with the case, two exhaust on the roof and one exhaust at the back which are noisy, no intake fans at all.
The case has the option of mounting two intake fans at the front, and a further two after the HDD cages as intake fans. I defiantly want to replace the exhaust fans and put two front intake fans but my question is, should i put the second set of intake fans after the HDD cages?
Also what type of fans would you guys recommend, really looking to make the rig as quiet as possible. I would go with noctua but they a bit pricey for me right now
