Fan Performance/Quietness
Prof93
Hi Guys,
I have been looking at lots of fans reviews and coolers but I have decided to stick with the cooler I have a change some fans.
I have a corsair 600t with the window fitted.
I have all stock the stock case fans minus the one in the roof because of the H100i. The H100i a new one due to having to RMA the first one for cracks appearing in the tubing. So it has the new PWM fans on it.
I am thinking of upgrading the fans with these and would like to know if I have chosen correctly or if there are better products I could have chosen.
Noctua NF-S12A PWM Fan - 120mm X1 For rear exhaust
Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan X2 For H100i
BitFenix Spectre PRO 200mm Red LED - Black X1 For front intake
System Spec:
AMD 8350
AMD R7950 Twin Frozr 3GD5/OC (non boost)
ASUS CROSSHAIR V FORMULA-Z
MUSKIN BLACKLINE 2133mhz 8GB
OCZ 60GB SSD
Seagate 2TB HDD
Corsair H100i
Corsair TX 850M
Corsair 600T
Corsair K65 / M65
Thanks in advance :)
the fans you have chosen should give you a decent noise reduction, and possibly may shave a few degrees off your cooling
I have the Bitfenix Spectre pro 200mm front :) really a great fan but be aware of the hdd cages, it is a very tight fit, it is possible ;)
If I had a 600T again I would mod it to fit two 120mm's in the front, remove all of the plastic bracing from the covers and then get 550/900D style magnetic fan filters for it all. Even with the hard drive cages removed and a fatter front fan put in my temps with SLI air cooled cards were tragic compared to a 550D, yeah a quiet case :/, 200mm fans are totally not the nuts.
So personally I would get 2x SP120 PWM's and 3x AF120 Quiets.
JR
