magicc8ball
So I am getting the NZXT switch 810 for my next case and since it does not have a fan controller I need to add one.
What fan controller do you all recommend?
I will be running a 280 mm rad in the bottom with the push pull configuration and a 420 in the top in push pull as well.
There will be a total of 12 fans in the case, is there a way to set up the 7 fan distribution block so that I can controller it all from the controller or no?
Any guidance here would be great, this is my first time to mess with fan controllers.
Thanks everyone!
Thanks everyone!
