Fan controller
The Phanteks PWM fan hub can handle 11 three or four pin fans and controls them all from one PWM motherboard header.
Looking a good fan controller that can handle 13 fans and can be hidden inside the case any ideas ?
If you want to hide it out of sight just push it deeper into the case and drill some custom screwholes there so you can keep the case stock front cover in place in front of it.
I've hidden a couple of DVD drives like that as well that people wanted to have but not wanted to see.
This was my solution, 2x Aquaero 5 LT's giving 8 channels of voltage control, 6 of the channels have a pair of radiator fans on them, the rear exhaust fan has it's own channel and the LED's are on the remaining one. I hid it behind the front radiator and had Pexon make me 6 custom length splitters that were assembled through the motherboard tray.
JR
i take my hat off to you sir , that is sexy modding right there , and there me thinking can you run 2 corsair command mini in one system
6/7 or 13 of them?... That will just look ugly as shit bro :lol:
You can get 5/7/12v splitters that go 1 molex < 6x 3-pin fans, I personally prefer this as you just set up your fans at a volume/airflow that is acceptable, then you never have to worry about fan speeds again. Whereas with a controller you're forever twisting knobs when going from surfing internet to playing games... just seems unnecessary to me.
In addition, if your case has half-decent cable management then it's not too hard to hid all the cables round the back; no harder than hiding 13 fan cables coming out the back of a fan controller.
I need the controler because i am useing all the fan are on rad and looking the rig to be super quite
5v splitters will make fans spin at 41.6% speed and 7v will make em run at ~58%. Most 1200rpm fans will be utterly silent @5v and reasonably quiet @7v :P
Just the way I personally choose to set up fans, not trying to be pushy :P
