Fan Controller Read-Out Fluctuations -- Normal?
david__001
Hello folks,
I wonder if anyone can tell me whether some fluctuation in the readings on the display of a fan controller is normal.
After I set a voltage dial (or "knob"), the values often fluctuate. For example:
* if I set a dial so that the voltage is "about 8 volts", the voltage typically fluctuates over a range of 7.8 to about 8.2 volts from then onwards.
* if I set all the dials to their maximum, the voltage typically floats over a range of 11.8, 11.9, or 12.0 volts.
* if I set a dial to "around 6.5 volts" the voltage typically fluctuates over a range of about 6.3 volts to 6.7 volts.
And so forth.
Is this normal? I had previously thought that after setting a voltage, it would always stay constant after that point.
I have taken a video here (60 seconds): http://www.youtube.com/watch?v=Vvh-RQ20Ui8 (The video features voltages that are quite low from the range I tend to pick from.)
Any thoughts are most welcome.
PS:
Fan controller: Lamptron FC5 V2 (molex powered) (I have been very happy with this unit overall by the way.)
Power Supply: Corsair AX860 (exhibits "coil whine", sadly)
Fans: 2x Corsair 650D 200mm stock, 1x Corsair SP120 Quiet Edition (standard/non-PWM).
Thats pretty normal mate, dont worry my fan speeds are the same +-150rpm but there is no visible change in noise coming from the fans...
