Fan cable sleeving
Bungral
Howdy..
Soon gonna be water cooling my rig and am gonna be mounting a PA120.3 off the back of my case.. I have fan extension leads so they will reach a fan controller on the front. I'll want to sleeve these though and just want suggestions on which sleeving is best fitting and easiest to use really.
Actually just thinking about it.. Sleeving big enough to fit all three in one would also be an idea??
Ta
I've just finished sleeving a couple of fans with that stuff, got a load more to do.
I was finding 4mm OK for 1 fan, so go for 6mm or 8mm.
As for the heatshrink, I bought the stuff for 3/4mm braiding and it was too small, I would have been better off with the next one up, so go next one up yourself too if there is one :)
Ok got it all and braided up 4 redwing fans which are a pig as they have molex and 3 pin as well as braiding up 4 extension cables... 3 more to do when they arrive. Had a lil braid left so braided my DDC Ultras power lead. My finger for very sore from removing all the sodding plugs!! Pics ummmm either tonight.. Tomorrow night or when I setup the whole loop.
