Fallen Angel
absolutly love this, wish i had the patience to do a build like this, i just trow stuff together, you make your stuff.
Love it !
you sire are a steely eyed missile man. Awesome Job. I am considering getting back into hardcore modding again but my budget suxs for it lol. I have a couple old build logs on another forum from when I did this before one I am extremely proud of the other well the thought was there but it lacked dearly IMHO in exacution.
But anyway SIMPLY AMAZING JOB!!!!!!!
Before cracking on with the mootherboard prep I wanted to clear up a few odds and sods so 'carbonised' the GPU's to match the build:
Next up was the window mod.
The case came with a mesh panel:
but I prefer perspex, black tinted of course:
Needs a good polish with anti static but looks sweet in situ
Time to finally start building. I seem to have spent so long preping and modding stuff
Anyway here she is, the Rampage III Extreme:
The perfect motherboard to match the case and build:
After prepping the motheboard by removing the stock 'cement' with some MX-3 I set about mounting the heatsink, Prolimatech Super Mega:
Love the mounting hardware of the Super Mega. Easy but with 70lbs of pressure thanks to the optional black screws it should be effective
Dunno if the copper fins will make that much difference but I managed to get the cooler for the same price as the all aluminium megalahems so I'm not not complaining:
Mounted:
I originally had the Bitfinex Spectre 120mm fans planned for the HS but it made it look too black so I plumped for Prolimatech Vortex 140mm in push pull:
Memory in situ:
Sadly the board and tray together wouldn't fit into the case in one go thanks to the size of the cooler so I had to hide cables as I went rather than do a big cable tidy at the end of the build:
I also used the same fans on the intake door:
For the lighting in this build I was just going to let the LED fans do their bit but to add a few minor highlights to the rest of the build I decided to add an LED string, hidden behind the motherboard:
With that done it was pretty much plain sailing apart from hiding all of those cables I spent so long braiding!!!
Finito!!!
This is one awesome rig !
Can you upload some pics of the rig in the dark ?
I would love to know how that motherboard lighting looks !
