fake memory
Creditor
i just bought Hynix DDR III HMT351U6BFR8C-H9N0. this is what cpu-z says:
is it fake? should i return it to the store? i checked it with memtest86 and it has no errors
that is correct:
MPPU = ???
4GB = correct
1333 = correct
8chips = correct
the HMT351U6BFR8C-H9N0 is a batch number, NOT a part number
It's fine. CPU-Z shows the part number, hence why it says MPPU4GB13338Chips. 4GB per stick, the kit is rated at 1333Mhz, and there's 8 memory chips per stick
