External sound.
Dawelio
Active member
Question for the audiophiles in here, I currently have an Focusrite scarlett solo 4th gen and was wondering if anyone has any tips on an smaller unit? I have mine mounted under my desk, but curious if there's anything smaller out there essentially. I basically only use it as an raw audio output. No inspruments or so, just the front headphone port and back microphone XLR port essentially. Hence 75% of the body is unused
If I've read that right, You still use the XLR port and want one with it or want a unit with just headphone audio ?
Both preferably, since I might use the microphone. Just would like an smaller unit than my current Focusrite Scarlett 4th gen.
The scarlett solo 4th gen is already pretty small so not sure why you'd want to get rid of it but if for some reason you need smaller then the Shure MVI Motiv Digital Audio Interface should meet your criteria.
As you can see, Very tiny, Has both XLR and audio that plug in at the rear -
Screenshot 2025-05-11 at 23-04-33 Shure MVI Motiv Digital Audio Interface - Google Search.png
So you are only using it as a DAC for headphones? Well, and obviously a headphone amp?
Or are you using the mic port?
Personally I would get a USB mic. I would then look into the Chord Mojo II. It's portable too.
