Exhaust for top mounted radiator
Ray Marree
With a top mounted radiator do u want the fans to pull air in to the case. This would be using the coolest air possible from room. Option 2 would be to push the hot air out through the radiator in to the room.
So which option is better?
Thanks guys
roof/top exhaust.
not that much in temperature difference between the roof as intake or exhaust.
easiest to remember, dust will not enter from the top if exhaust.
eventually what is in the case in heat will become room air..
