I have this mobo (P5N32-E SLI), only recentley installed so just getting used to the bios and might i add there are a lot of settings most i keep on auto like DDR2 ref Voltage etc, the board seems
stable out of the box (early bios), i can't remember what bios it shipped out with, quad core support out of the box, i have just flashed the bios revision to 1102, all seems well but oddly enough and i was quite suprised to read this bit about crossfire issue, so it's SLI and crossfire compatible.
Version 1102 2007/05/29 update
OS DOS
Description P5N32-E SLI BIOS 1102
1. Updated NV RAID ROM.
2. Support new cpus. Please refer to:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N32-E SLI
3. Modified warning threshould of CPU fan speed.
4. Fixed ATi Crossfire fail issue.
5. Enhanced compatibility for certain memory modules.
6. Fixed incorrect display of L2 cache size when using Conroe-L CPU.
