name='Waffles' said:what are your thoughts on the EPoX EP-5LWA+? is there a better motherboard for around the same price?
harmonicgen007 said:okk this is the one he wants to get
http://www.newegg.com/Product/Produ...tegory=20&minPrice=&maxPrice=&Go.x=17&Go.y=33
or you could look at this
http://www.newegg.com/Product/Product.asp?Item=N82E16813130464
http://www.newegg.com/Product/Product.asp?Item=N82E16813130461
http://www.newegg.com/Product/Product.asp?Item=N82E16813136145
http://www.newegg.com/Product/Product.asp?Item=N82E16813136148
there just a fewenjoy
name='Waffles' said:so those ddr/ddrII mobos work alright then?
name='harmonicgen007' said:yepp there fine, just ask envias about how good the DFI's are and PV5150 how could the MSI neo2's are![]()
name='NickS_' said:Yeah I'd go with the DFI 915p, or teh 875. XMS had that 875 took his p4 to i think 4.6ghz dont quote me.
name='NickS_' said:you cant always have what you want, and i'd go with DDR1. XMS must have chosen it for a good reason!
XMS said:TBH i wouldn't invest in anything DDR2, its gonna die before it even takes off. Hence the reason why AMD have held back on production of a chipset that supports DDR2.
But its ur call![]()
NickS_ said:good mr DDRII, or, TEH SUK.
AMD for your info, is going DDR 3.
name='Dave' said:an intel on ddr1 wd also rip dvd's faster than an equivelant amd. and if you evr wanted to upgrade to something else, ddr1 wd be good for other computers (specifically amd ones)
